How to gracefully change: SR, AudioDriver, channel swap..
Postby chjan » Tue Feb 22, 2022 1:25 pm
I have a problem for many years, and today I am investigating if it can be solved:
When changing AudioDriver (the drop down module), or changing left and right channels as I do in my testbed, or stopping and restarting a stream, it happens (many times per day) that Flowstone does not like that. It crashes.
Thus, is there a way to inject a module or mechanism that ensures that such "live" operations on a stream are always done gracefully?
Graceful example from Java: AudioLine.stop, then AudioLine.close. Now a new line can be started.
Thanks for any help on this.
chjan
Re: How to gracefully change: SR, AudioDriver, channel swap.
Postby Spogg » Tue Feb 22, 2022 4:17 pm
I used to get this from time to time on FS 3.08.1 but since I changed to 3.06 it’s pretty much not happened.
Postby nix » Wed Feb 23, 2022 5:23 am
I don't know of a way
-yes, that does happen
it happens often when switching schems with audio on
nix
Postby chjan » Thu Feb 24, 2022 4:27 pm
As audiodrivers, I have only ASIO4ALL and RME Madiface USB.
The latter gives this problem, let's say, every third time. ASIO4ALL never exposes this problem. And further to that, if Flowstone is "moody" like this, then I have found I can launch ASIO4ALL first, then Madiface, and then Madiface is always accepted.
This also happens when starting from scratch, i.e. with audiodriver = NONE.
Is there someone here that can take a look at the asiodriver selector (the module with driver, samplerate and asio settings), and investigate if audio stream is stopped when user clicks the dropdown, or otherwise?
I just mention this in case someone passes who gets ideas from the description.
chjan
Users browsing this forum: No registered users and 25 guests
