Midi Input LED Blinking
Hi guys. This should be a simple one for you geniuses.
I want to put an LED on a plugin and have it blink whenever a midi signal comes into the module input which is a MIDi input. For example, if CC1 comes in it will blink on and then off. When there is no signal coming in it will be off.
How do I do that? Thanks in advance.
- S1User
Re: Midi Input LED Blinking
Never mind. I found it already built here: viewtopic.php?f=3&t=3809&p=21604&hilit=midi+activity&sid=95783f33f37cb9fe64a69439ff45748c#p21604
- S1User
