FlowStone Crash Dump Manager
Postby pwesynthmaker » Sat Apr 02, 2022 11:55 am
Download Link:
https://www.inventorefx.com/_ifxfstone/flwstcrshr.zip
Filename: flwstcrshr.zip
Written as a powerful batch file script. Extensively tested for errors and compiled into executable with Licensed Commercial Version Advanced Batch To Executable Converter Software Designed by B. Dargo.
A versatile management command line style console for removal of the FlowStone Crash Dump Items.
The FlowStone Crash Dump Manager is self-explanatory and easy to use with the following features:
Removes FlowStone Crash Dump Folder/Files with verification.
All options are simply YES or NO with absolutely no guesswork needed. Very simple to use even for beginners and fast operation for the well versed 'Flowstoners' in our midst.
Last edited by pwesynthmaker on Sun Feb 08, 2026 2:41 pm, edited 6 times in total.
Inventor eFX Technology
pwesynthmaker
Re: FlowStone Crash Dump Manager
Postby pwesynthmaker » Sat Apr 02, 2022 12:00 pm
FlowStone Crash Dump Manager.Batch to Executable Script
:: RUN AS ADMINISTRATOR ::
@echo off
if _%1_==_payload_ goto :payload
:getadmin
echo %~nx0: elevating self
set vbs=%temp%\getadmin.vbs
echo Set UAC = CreateObject^("Shell.Application"^) >> "%vbs%"
echo UAC.ShellExecute "%~s0", "payload %~sdp0 %*", "", "runas", 1 >> "%vbs%
"%temp%\getadmin.vbs"
del "%temp%\getadmin.vbs"
goto :eof
:payload
color 4f
echo.
echo.
echo AT ANY TIME DURING THE FOLLOWING PROCEDURES ...
echo TO EXIT WITHOUT CHANGE ...
echo ONLY PRESS "X" CHECK BOX IN UPPER RIGHT OF THIS WINDOW!
echo.
pause
if exist %Userprofile%\AppData\Roaming (
goto :rmvcrsh
) else exit
:rmvcrsh
echo.
echo.
echo To REMOVE Crash Files ...
echo Type "Y" For YES Then Press "ENTER".
echo.
echo Or Press Any Key To EXIT ...
set "reply=n"
set /p "reply= %USERREG%"
if /i not "%reply%" == "y" goto exit /b
cd %UserProfile%\AppData\Roaming
if exist %UserProfile%\AppData\Roaming\"Crash Dump" (
rmdir /q /s "Crash Dump"
echo.
echo.
echo CRASH DUMP FOLDER REMOVED.
echo.
echo.
pause
) else goto :flwstnzip
:flwstnzip
cd %AppData%\FlowStone
if exist %AppData%\FlowStone\"FlowStone *.zip" (
del /q "FlowStone *.zip
) else goto :crshdmp
:crshdmp
if exist %AppData%\FlowStone\CRASH.* (
del /q CRASH.*
) else goto :errlog
:errlog
if exist %AppData%\FlowStone\ERRORLOG.TXT (
del /q ERRORLOG.TXT
) else goto :rprtexe
:rprtexe
if exist %AppData%\FlowStone\report.exe (
del /q report.exe
) else goto :nocrsh
goto :crshovr
:nocrsh
color 2f
echo.
echo.
echo NO CRASH FILES EXIST.
echo.
echo.
pause
exit /b
exit
:crshovr
color 2f
echo.
echo.
echo ALL CRASH FILES HAVE BEEN REMOVED.
echo.
echo.
pause
:eof
exit /b
exit
pwesynthmaker
