Req: Clear Search box after clicking on Tag like in SM
... says it all.
After a search u end up with a blank toolbox if u click on a tag where u know that the next mod may sit that u like 2 drag into ur schematic window...
btw: Help and Component PDF please back into Help menu...
Re: Req: Clear Search box after clicking on Tag like in SM
Hi Walter - the tags, type filters and search all act together. This allows you to search for something and then filter further by tag. If we cleared the search each time you click a tag you wouldn't be able to do this.
The behaviour is consistent across all the filter options - click on a type filter and it doesn't clear any search or tags you have set, do a search and it doesn't clear the tags or type filters and so on.
You can always clear the search manually by pressing the escape key. This will clear the search and type filters but leaves any tags.
The manuals are now on the Download menu btw.
support - Posts: 151
