Schmidt Trigger (Blue)
I made a Schmidt Trigger for Green, however I need a Schmidt Trigger for Blue.
Anyone that can perhaps help out, as I do not know DSP Code ?
It should have a Setting which can be Set for ON and OFF for different values between the zero-axis and curve peak (Sine wave) as well as Sine In and Clipped (when it switches On/Off) Sine Out.
Thank you in advance.
tiffy - Posts: 400
Re: Schmidt Trigger (Blue)
Here you go, Tiffy
SchmittTrigger.fsm- (11.24 KiB) Downloaded 893 times
martinvicanek wrote:Here you go, Tiffy
Wow Martin, that was quick.
Thank you so much, I appreciate.
Best regards. Have a nice Christmas & Happy New Year too.
tiffy - Posts: 400
