Save Bitmap Image
Save Bitmap Image
Postby Perfect Human Interface » Sun May 24, 2015 10:27 am
A very simple tool for when you want to pull a loaded bitmap from a schematic and save it to your hard drive.
Could also be easily adapted for any project where you want to save a bitmap to disc.
Supports png, jpg, bmp, gif, and tiff filetypes. Just type the extension you want in the save dialog and it will encode properly, unless you type in something invalid of course!
Enjoy?
Save Bitmap Image_PHI.fsm
(26.01 KiB) Downloaded 1330 times
Re: Save Bitmap Image
Postby StereoSpace » Sun May 24, 2015 11:01 am
Big Thanks!!!
GUI designer
StereoSpace
Postby Nubeat7 » Sun May 24, 2015 4:23 pm
why should i load an image and save it somewhere else with flowstone, isn't it easier to do it with windows?
Postby Youlean » Sun May 24, 2015 5:31 pm
Maybe this will be more useful...
Youlean View to Image.fsm
(3.31 KiB) Downloaded 1246 times
Youlean
Postby Nubeat7 » Sun May 24, 2015 11:23 pm
yes youlean this makes much more sense, the tricky thing is to capture the view, i use a similar methode to capture the backgrounds for my apps or for the knobstrip maker
viewtopic.php?f=3&t=3283&p=17599&hilit=knobstrip#p17599
view snapshot.fsm
(5.29 KiB) Downloaded 1204 times
Postby Perfect Human Interface » Sun May 24, 2015 11:56 pm
Nubeat7 wrote:why should i load an image and save it somewhere else with flowstone, isn't it easier to do it with windows?
It's just for if you already have an image loaded into a schematic and want to get at it. Maybe you don't have access to the original, maybe you don't know where it is or maybe you want to edit an image in a schematic you downloaded from someone else. That's all; not meant to be a game changer. :P
Postby billv » Wed May 27, 2015 2:35 pm
Youlean wrote:Maybe this will be more useful...
i Needed this when i was building the Pixel Art drawing thing a while back.
But didn't think it was possible and neglected to ask.
Thanks for sharing...
Cheers.. :D
