Thru Zero Flanger
Thru Zero Flanger
Hello Gang,
Ok, I was mostly just playing around with this for myself, but I have some problems and could use some kind help please.
The problem at preset it is, it is kind of noisy, lots of clicks, crackles, and etc. So any thoughts on cleaning it up would be great. Also any other changes you would like to make, please feel free to do so.
Thanks all! Later then, BobF.....
- BobF
Re: Thru Zero Flanger
Hi BobF
I simply replaced the delay with an interpolated delay here, which should solve your scratchiness issue.
Sounds good with a little tweaking.
- Perfect Human Interface
Hi Perfect Human Interface,
Thank you so much, sound very clean now.
Until next time, BobF.....
- BobF
