Working with data in a text file accessing by http:\\....
Postby astroghost » Tue Dec 08, 2015 11:57 pm
Hello ,
i'm trying to accessing data from a sensor.
The data file could be accessed to this address :
http://127.0.0.1:4444/bySerial/LIGHTMK2 ... Sensor.txt
Data are like this in the text file :
*** lightSensor
logicalName: ""
advertisedValue: "17.5"
unit: "lx"
currentValue: 17.6
lowestValue: 3.5
highestValue: 82.6
currentRawValue: 17.617
logFrequency: 1/s
reportFrequency: OFF
calibrationParam: 0,
resolution: 0.1
measureType: HUMAN_EYE
So i would like to make a module that can read this text file each minute then get the datas on line 6,7,8 line ( lowestValue
highestValue
currentRawValue )
How can i make this module in flowstone.
Thanks for your answers
François
astroghost
Re: Working with data in a text file accessing by http:\\...
Postby Tronic » Sun Dec 13, 2015 9:52 pm
Can you give more information on what kind of hardware are you using?
Tronic
Postby JB_AU » Thu Dec 31, 2015 9:35 am
So you have a file of sensor data on your local server, you could treat this as a normal file/folder & build a path to it, import the data into a string array, index 5,6 & 7 holds the required information, lucky for you there is a ':' delimiter, so you only require float data from index 5 after ':' delimiter.
All the information you require is in the user example subsection :)
Albert Einstein
JB_AU
Postby frontfitters123 » Wed Mar 30, 2016 10:53 am
If you know a little bit how to work with php and Html then you can easily make a program that will read this text file after a giver time will update your database. All you need and ISR system, ISR 2.3.0 will work.
We are the best Shop front fitters in London. Contact us and give your customers a better first impression.
frontfitters123
