Bobs Wave Slider Synth
Postby BobF » Wed May 10, 2017 4:32 pm
BobsWaveSliderManual.rar
(177.31 KiB) Downloaded 1207 times
Hello gang,
Here is my 3rd Synth. It is called the Wave Slider Synth because the big difference with the oscillators is that you can slide the positive part of the waveform while the negative part stays stationary. I have provided you all with 25 presets to get you started and also do please read the manual (rar file), it tells all.
Have fun and please if you create any new presets please post them along with any suggestions, bug fixes, and so on.
Later then, BobF.....
Bobs_WaveSlider.fsm
(405.13 KiB) Downloaded 1106 times
BobF
Re: Bobs Wave Slider Synth
Postby BobF » Wed May 10, 2017 9:26 pm
HELP ! It's been reported already that this synth can only be made into a EXE and NOT a DLL.
Does anyone see the reason this would be so?
Thanks all.....
FIXED
BobF
Postby Wassaka » Wed May 10, 2017 11:02 pm
BobF wrote:HELP ! It's been reported already that this synth can only be made into a EXE and NOT a DLL.
Thanks all.....
You can not export it in VST because there are no midi inputs or mono outputs. Here is the schematic with input and outputs.
BobsWaveSlider_inputs.fsm
(405.13 KiB) Downloaded 1114 times
Wassaka
Postby BobF » Thu May 11, 2017 2:49 am
Thanks Wassaka ,
Must have been a senior moment.....
BobF
Postby Spogg » Thu May 11, 2017 9:18 am
Hi Bob
Yet another interesting technique!
I quickly tried the presets and I'm impressed but I will spend a bit more time with it on my return.
The GUI colour makes it look more "modern" somehow too.
Thanks for sharing and your stuff is always inspiring.
