Random graphic Lines
Re: Random graphic Lines
Postby tulamide » Wed Nov 24, 2021 7:34 pm
Whenever you draw something to a view, you're actually drawing into a bitmap. Once some drawing is finished, the bitmap is shown in the view, further updated by more drawing, etc. It stays in its last state, until something else covers it. At that point the view is instructed, which part to redraw ("clipping") and it clears everything from that part of the bitmap. When you don't draw again after that, it just stays clear (clear = transparent).
This all has nothing to do with Ruby (nor green). It's just how drawing is handled in Windows.
Postby hardwarehost » Wed Nov 24, 2021 10:49 pm
...32bit finally
I pushed it to different direction, theres 12 fully controlled rectangles but during the time I experimented too much for freaky effects. Its a fast mash-up. I will work on it further anyway to get something similar of what it was at the beginning.
Random Graph _32hwh 2.fsm
(457.4 KiB) Downloaded 1305 times
hardwarehost
Postby DaveyBoy » Wed Nov 24, 2021 11:39 pm
Wow . . . Ive never seen it this high before:
Using the Alpha, I'm impressed :D
DaveyBoy
Postby hardwarehost » Thu Nov 25, 2021 12:10 am
You see its 5 times in schematic I wrote its a fast mash up :?:
hardwarehost
Postby Tepeix » Fri Nov 26, 2021 3:04 pm
Thanks Tulamide.
From what i see in host it only draw when we ask or when something hide the view or a part.
Strangly when the vst window is moved there's no redraw.
I suppose it redraw the view at refresh but only redraw the bitmap when call.
Interesting Art HarwareHost, i think that the creator of random make it more close that what could more represent something close to his mind.
Maybe there's some module that could reduce tick in this schematic.
I make a random color change that's more simpler. This one could change speed but not
so much.
Also i use a method to produce ticker at different speed in one place then send wirelessly all the ticks.
So a module that need slow tick will not add his own counter to the list.
I also go wireless to send the size or area of the view.
I will someday try a method to add smooth transparency border with png.
For now i experiment with bitmap feedback or smoothing..
Using the create bitmap with less pixels will add some strange blur.
GraphicBitmapFeedback.fsm
(32 KiB) Downloaded 1259 times
Tepeix
Postby Tepeix » Sat Nov 27, 2021 3:25 pm
Finally here's a way to make transparent traces.
But we end up redrawing all the view and not only part for a perfect result.
Maybe it's possible to redraw only part, drawing first the bitmap recorded background,
then the trace we want to add.
transparentTraceRedraw.fsm
(74.22 KiB) Downloaded 1249 times
Tepeix
Postby hardwarehost » Sun Nov 28, 2021 12:47 am
Snap 2021-11-28 at 00.38.58.png (13.56 KiB) Viewed 27335 times
I searchd the forum and found the View Cache module by Trog, now it fills all area forever or draw the line from moving object.
added xy "drawing" pad
Random Graph _32hwh 5 still.fsm
(824.8 KiB) Downloaded 1331 times
hardwarehost
Postby Soundshaperzkitz » Wed Aug 30, 2023 10:58 pm
Just curious, how would I drop one of these custom modules into an existing flowstone vst project?
TIA!
Soundshaperzkitz
