Advanced Envelope
Advanced Envelope
Postby Father » Tue Mar 24, 2015 3:18 pm
This is a tool that can be used to control other parameters to change in time. You can use it to control volume, filters...etc. Hope it could be useful and maybe someone could find and fix the bugs or come up with something better.
Special thanks goes to TheOm for his beautiful work on Line Editor, and Nubeat7 for his help with position sync.
Known issue: It doesn't always load right, specially in bigger projects, apparently due to ruby's loading problems.
enjoy.
Advanced Envelope.fsm
(496.6 KiB) Downloaded 1508 times
Father
Re: Advanced Envelope
Postby Perfect Human Interface » Tue Mar 24, 2015 9:23 pm
I was just thinking about creating an envelope from TheOm's editor for a project myself. Will have a look for sure; thanks!
Postby StereoSpace » Fri Mar 27, 2015 11:32 pm
Wow)) Thanks!!!
GUI designer
StereoSpace
Postby StereoSpace » Wed Apr 29, 2015 4:08 pm
Thanks!!!
GUI designer
StereoSpace
Postby lalalandsynth » Wed Oct 05, 2016 2:47 am
Wanted to try this , has an error inside module , seems to be the code.
Is there a more recent version or something similar , looking for something like the Envelope in Massive.
lalalandsynth
Postby lalalandsynth » Sat Oct 08, 2016 6:45 pm
Wondering if this works for other people , seems to be an error in the preset setting .
Does not work at all for me at the moment , might be doing something wrong ?
lalalandsynth
Postby lalalandsynth » Tue Oct 18, 2016 8:21 pm
Sweet, got it working , anyone have an idea how i can resize this thing ?
Any attempt will crop the grid which makes it work wrong.
lalalandsynth
Postby Wassaka » Mon Oct 24, 2016 8:41 am
lalalandsynth wrote:Sweet, got it working , anyone have an idea how i can resize this thing ?
Hi! To resize it, just resize like a normal module and then press double click on "line editor" to resize it. (Sorry for my bad english :? )
Advanced Envelope (Resized).fsm
Here is an example.
(163.84 KiB) Downloaded 1308 times
Wassaka
Postby lalalandsynth » Wed Oct 26, 2016 1:05 am
Yes, but now you have 12 grids instead of the needed 16 .
It does not work properly like that.
lalalandsynth
Postby lalalandsynth » Tue Jul 11, 2017 12:05 am
I have built a plugin around this advanced envelope but during testing I noticed that it creeps up in memory usage .
Faster if the GUI is open.
Can anyone check and confirm ? Tested 3 computers. 3.08 export as well as 3.09.
lalalandsynth
