CSV2Display(Datasheetview)
Hello forum members
Since I have found no tool, which represents csv files I have written myself one.
It mainly consists of ruby code.
For a better understanding, I have just designed it as a module.
If you need it, you can split it accordingly and, for example, to use Lyric texts in MIDI.
The module [CSVtoARRAYa.fsm] was created under "FlowStone 3.0.9 Beta 2"
The module [CSVtoARRAY.fsm] was created under "FlowStone 3.0.8"
I'll later add more tools as soon as they run error-free
Greetings Pali64
Greetings Pali64
CSVtoARRAY.fsm- FlowStone 3.0.8
- (10.16 KiB) Downloaded 1151 times
CSVtoARRAYa.fsm- Work at FlowStone 3.0.9 Beta 2
- (10.32 KiB) Downloaded 1085 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World
Pali64 - Posts: 22
Re: CSV2Display(Datasheetview)
It looks impressive!
What are you using this for in practical terms? Is there a music-related use for it?
Hello Spogg
Yes I use it to display Lyric from MIDI files synchronized in bars(MIDI clock).
To do this, enter the bars of the sung syllables on the [Row in]
The sung text passages with [,] separated from the midi file on [CSV_In]
This can be placed as a semi-transparent text field over the notation
Greetings Pali64
Spogg wrote:.... Is there a music-related use for it?....
Greetings Pali64
Pali64 - Posts: 22
Fascinating! And you did mention lyrics in the original post.
I wouldn't mind seeing a screenshot or something to illustrate what you mean.
I had thought that CSV was really just for diaries and address books and so forth.
Thanks for sharing this unusual project. Another diverse application of Flowstone, always appreciated.
Hello Spogg
Here is an useful Example to use as a CSV Databankviewer
I think help an Alien and much other to Understanding where to do
Greetings Pali64
Greetings Pali64
CSVfileviewer.fsm- CSV Databankviewer in FlowStone 3.0.8
- (1.15 MiB) Downloaded 1057 times
Pali64 - Posts: 22
