Timing
Re: Timing
rewiredrecords wrote:I checked out that Grey Synth and tried using the Sequencer part of it but i still get the same issue - an extra sequencer note after the MIDI input has ended.
Have you tested Grey Synth being triggered by MIDI input or do you just have it always playing when FL is playing? Maybe you wouldn't notice the issue if you aren't using MIDI input but I can't see any way to use the sequencer in a full track if you can't control when it starts and stops in the song (like if you just wanted it to play in the middle of the song and nowhere else).
I'm not getting any errors from Greysynth. I just tested it in Reason and it's running fine Via midi input or
host sync. I usually use the host sync and just record the audio, then delete the synth and just work with the audio recording.
