ROXY's Phase Inverter
Postby rocknrollkat » Mon Dec 04, 2017 2:40 pm
Hi Gang,
Have any of you real world electronics guys (like myself) wondered why there's no phase inverter anywhere in Flowstone ?
They supply some of the most abstruse modules and primitives, but no audio phase inverter.
Yeah, I know it's not an 'electronics' modeler, blah blah blah, but c'mon, no phase inverter ?
So I decided it's time.
A word of caution first, though.
For simplicity's sake I was using the stock 'scope'.
You may not have run into this yet, but here's where I initially got 'thrown'.
Above 20 Hz., the A and B traces 'merge' and have the SAME phase !
Say WHAT ?
Luckily I have a lab grade scope handy and I ran my hookup through it instead and I've included a 1 kHz' trace for you.
Then I decided to see if there were any 'scope alternatives in my toolbox, and BobF's scope is WAY better than the stock scope, so I've included it in the hookup, and yes, it maintains phase above 20 Hz. !
Anyway, I developed this Dead Simple phase inverter that I'm sure many of you will find handy down the road.
Enjoy !
ROXY :D
ROXY's Phase Inverter.rar
Another stocking stuffer for you !
(259.84 KiB) Downloaded 1002 times
rocknrollkat
Re: ROXY's Phase Inverter
Postby tester » Wed Dec 06, 2017 10:18 pm
Phase inverter: multiply output (scaled in range between -1 to 1) by -1 :mrgreen:
Postby rocknrollkat » Thu Dec 07, 2017 11:20 am
In life there are usually several ways to accomplish the same goal.
Here's my inverter compared with Tester's inverter.
As you can see, the results are identical.
Thanks for the input, Tester !
ROXY :D
ROXY's Phase Inverter w. Tester's method.fsm
Two inverters compared !
(162.03 KiB) Downloaded 970 times
rocknrollkat
