[Ruby] Quote(') and double quote(") explained
Even as a beginner, you probably saw that you can use quotes or double quotes to assign a string:
That doesn't mean they're redundant. But their behaviour only differs in two situations. The first one happens, when the text you want to assign as a string contains a double quote or quote. You then need to use the other one to build a string, or else you get an error:
The other situations are escaped control signs. The ascii set contains control signs like new line, tab, return and others. Those can be used in strings to format them:
With single quotes, the characters are not interpreted, but taken as they are:
This is very handy, when you consider Windows. Say, you have a folder named music, containing a folder named rave, which contains a folder named new and lastly it contains a folder named tulamide. See what happens if you use double quotes:
Two lines of nonsense, that Windows will complain about. With single quotes it ends exactly as you need it:
Very comfortable! But to add to your confusion, there's a way to get to the correct result with double quotes as well. And if I wouldn't mention it, chances are the gurus will chop my head off.
You can escape from the escape! This is done by adding a \ to every escaped control char:
But this the uncomfortable way, so I recommend single quotes instead.
mystring = "Hello World"
mystring = 'Hello World'
mystring = "Hello"World" #produces an error
mystring = 'Hello"World' #works as expected
mystring = 'Hello'World' #produces an error
mystring = "Hello'World" #works as expected
mystring = "Hello\nWorld" #will use seperate lines for Hello and World ( \n instructs a newline)
mystring = 'Hello\nWorld' #will just print Hello\nWorld, no new line is created.
mystring = "C:\music\rave\new\tulamide"
##results in:
C:musicave
ewulamide
mystring = 'C:\music\rave\new\tulamide'
##results in:
C:\\music\\rave\\new\\tulamide
##results in:
Re: [Ruby] Quote(') and double quote(") explained
I love these mini tutorials you do!
I do hope there'll be more to come.
Spogg - Posts: 3324
If I may QUOTE Spogg .... love em. Thanks T.
There is also another very important difference. Double quote strings allow string interpolation using special #{} command, that allows you to insert data into string:
You can get identical result by appending strings, but that's slower and slightly harder to read:
h=182
m=67.684
wh="Height: #{ h.to_s}cm Weight: #{m.round(1).to_s}kg" #-> "Height: 182cm Weight: 67.7kg"
bmi="Body Mass Index: #{ (10000*m/(h*h)).round(3).to_s }" #-> "Body Mass Index: 20.434"
h=182
m=67.684
wh="Height: "+ h.to_s+"cm Weight: "+m.round(1).to_s+"kg" #-> "Height: 182cm Weight: 67.7kg"
bmi="Body Mass Index: "+ (10000*m/(h*h)).round(3).to_s #-> "Body Mass Index: 20.434"
@Spogg & RJ
Whenever I spot something, that I think is not too complicated, I will do another post. Thank you!
@KG
Good point! I too use #{} a lot nowadays. In the beginning I did it the hard way of adding strings, just as I was used to from older languages. But #{} is such a very nice shortcut, whose functionality is present in other modern languages as well, so I guess it was inspired by them. Just a little correction: You don't need ::to_s. It is called automatically when the variable doesn't represent a string. "... #{h} cm ..." is sufficient.
Yes, the use of #{} is only possible in strings with double quotes, guys!
@KG
Users browsing this forum: No registered users and 54 guests
