[Ruby] Quote(') and double quote(") explained
Postby tulamide » Sun Apr 22, 2018 12:10 pm
Even as a beginner, you probably saw that you can use quotes or double quotes to assign a string:
mystring = "Hello World"
mystring = 'Hello World'
That doesn't mean they're redundant. But their behaviour only differs in two situations. The first one happens, when the text you want to assign as a string contains a double quote or quote. You then need to use the other one to build a string, or else you get an error:
mystring = "Hello"World" #produces an error
mystring = 'Hello"World' #works as expected
mystring = 'Hello'World' #produces an error
mystring = "Hello'World" #works as expected
The other situations are escaped control signs. The ascii set contains control signs like new line, tab, return and others. Those can be used in strings to format them:
mystring = "Hello\nWorld" #will use seperate lines for Hello and World ( \n instructs a newline)
With single quotes, the characters are not interpreted, but taken as they are:
mystring = 'Hello\nWorld' #will just print Hello\nWorld, no new line is created.
This is very handy, when you consider Windows. Say, you have a folder named music, containing a folder named rave, which contains a folder named new and lastly it contains a folder named tulamide. See what happens if you use double quotes:
mystring = "C:\music\rave\new\tulamide"
##results in:
C:musicave
ewulamide
Two lines of nonsense, that Windows will complain about. With single quotes it ends exactly as you need it:
mystring = 'C:\music\rave\new\tulamide'
##results in:
Very comfortable! But to add to your confusion, there's a way to get to the correct result with double quotes as well. And if I wouldn't mention it, chances are the gurus will chop my head off.
You can escape from the escape! This is done by adding a \ to every escaped control char:
C:\\music\\rave\\new\\tulamide
##results in:
But this the uncomfortable way, so I recommend single quotes instead.
Re: [Ruby] Quote(') and double quote(") explained
Postby Spogg » Sun Apr 22, 2018 12:22 pm
I love these mini tutorials you do!
I do hope there'll be more to come.
Postby RJHollins » Sun Apr 22, 2018 5:26 pm
If I may QUOTE Spogg .... love em. Thanks T.
Postby KG_is_back » Sun Apr 22, 2018 7:46 pm
There is also another very important difference. Double quote strings allow string interpolation using special #{} command, that allows you to insert data into string:
h=182
m=67.684
wh="Height: #{ h.to_s}cm Weight: #{m.round(1).to_s}kg" #-> "Height: 182cm Weight: 67.7kg"
bmi="Body Mass Index: #{ (10000*m/(h*h)).round(3).to_s }" #-> "Body Mass Index: 20.434"
You can get identical result by appending strings, but that's slower and slightly harder to read:
h=182
m=67.684
wh="Height: "+ h.to_s+"cm Weight: "+m.round(1).to_s+"kg" #-> "Height: 182cm Weight: 67.7kg"
bmi="Body Mass Index: "+ (10000*m/(h*h)).round(3).to_s #-> "Body Mass Index: 20.434"
KG_is_back
Postby tulamide » Sun Apr 22, 2018 10:19 pm
@Spogg & RJ
Whenever I spot something, that I think is not too complicated, I will do another post. Thank you!
@KG
Good point! I too use #{} a lot nowadays. In the beginning I did it the hard way of adding strings, just as I was used to from older languages. But #{} is such a very nice shortcut, whose functionality is present in other modern languages as well, so I guess it was inspired by them. Just a little correction: You don't need ::to_s. It is called automatically when the variable doesn't represent a string. "... #{h} cm ..." is sufficient.
Yes, the use of #{} is only possible in strings with double quotes, guys!
