generate 4 primary wave with a DLL
hello guys,
I return today with the fsm Codeblock dll project and a way to generate primary waveforms (tri, sin, square, saw) generated in a dll hoping that his can you helped
I think the code or fsm perhaps improved jugger you
edit : i'm added project in visual studio 2012 because translate asm is verry horrible on codeblock ;__; but now with this version tri,saw,square ans sin is phased.
http://www.sendspace.com/file/372dxa
- DjMmix
Re: generate 4 primary wave with a DLL
So now my question is:
1) Having an external wavetable based generator (with phase offset control, resync node and accuracy of timing).
2) Used in 200-400 copies (sound generation, modulation, etc.; intependent shape control).
Will/would it work faster than stock wavetable oscillators placed within exported FSM schematic?
And btw, should this be externalized as full wavetable generators (like these stock ones work), or non-optimized mono-generators, and then with additional output filter LP for the whole sound in FS?
Hi DJMmix and all
ive installed the codeblocks application and i was wondering about the compiler bit, Ive never tried doing anything like this exept for trying out VS2008 and my head was totaly pickled by it lol, so my question is - which compiler would be best for me to download and use?
dont know if this makes any difference but im on Win7 64!
thanks!
thanks!
- Jay
Jay wrote:which compiler would be best for me to download and use?
dont confuse IDE and compiler, code blocks or visual studio are IDE`s (development enviroments) while a compiler translates the source code (highlevel) into (binary) object code (lowlevel)
so an IDE uses a compiler to make an executable (or dll) from your source code
the most common compiler is the gcc compiler..
what IDE is the best? this really depends on personal taste, visual studio for sure is one of the best IDE`s
about the compilers visual studio uses its own microsoft compiler while other IDE`s mostly use the gcc compiler
beside code blocks there is also eclipse and net beans, eclipse originally is the nr 1java IDE but you can also use it for c++ there are lots more but i think from the free opensource IDE`s on the market codeblocks is one of the best for c++
any way for the purposes we will useit i think it doesnt make any difference which IDE to use
the only question which would be intersting is the support of the "new" c++11 standard (which is already old since the newest standard will be c++14!
maybe when you learn from a new book which already uses c++11 code you could get into troubles with VS 2008
while the latest gcc 4.8 compiler is mostly or full compatible to this new standard
for visual studio here is a table about this:
http://msdn.microsoft.com/en-us/library/hh567368.aspx
http://blogs.msdn.com/b/vcblog/archive/ ... 3-ctp.aspx
cheers for that reply Nubeat7! some of it was over my head but i got the jist of it
yeh i installed VS2008 before and got completly lost with it and couldnt get it to run simple stuff without lots of error messages that i didnt understand, found it a bit intimidating as well, ive already installed codeblocks and was trying to go through a tutorial on making a Dll and it asked me for a compiler so i went and looked on the net and seen that there were many and i read all the alien language in the descriptions of them ha ha,
So i installed the MinGW intalation manager and went for basic setup and sellected 2 packages for install, i have put in the one you mentioned i think! gcc-g++ ? i also installed the one called gcc-objc so are those for C and C++ i take it? or is objective C something different? soz for the silly questions but im rubbish at this stuff
so i will have a wee bash at this! which version of the C language would you recommend learning c or c++?
i will most likely play around for a bit with examples and other peoples code and try to learn whats what and then see if i can make some simple function dll's. but then, there is always the prospect of me just remaining baffled for a few months then giving up
thanks!
thanks!
- Jay
hmm, dont know exactly whats the thing with ocjective c as i understand it is the extended version of c, to use c, what is a procedural language, as an objective language but i think you will not need it..
my knowledge of all that stuff is very basic..
where to start? i would recommend to watch c at the beginning to get c basics and then go to c++ because c++ was growing out of c and is like the big brother of c
Hello everyone ,
for the choice of IDE is mainly a matter of taste as nubeat7 said , I prefer Codeblock which is much less load than VS (a by integration of asm in Codeblock is horrible ... )
for the version of Codeblock than to take one with mingw integrated configuration is automatic
hum cons I do not know if you take the 64-bit version if you can compile 32 bit for FS is 32 bit so the dll function will be 32 bit but it is still a test
@ tester :
I currently working on the integration phase at the moment (sin,square ok,but tri and saw not implented ) to sync I also above board
in terms of creating 200 400 I do this is not yet the same dll I actually worked 2 module coupled then I think to put it more should be possible, but I is not the limit :/
for wavetable I saw the snippet from here and there on the net so I think this is quite possible.
I was recovering update the link with the first post that I changed and added ( for Phase I took the standard used in FS that is to say 0 .. 1 ) I have also added white noise and said the trick trogludite to see the scope to see the motionless waves
edit : added phase on tri and saw work perfectly with vs 2012
@ tester :
- DjMmix
Hiya Nubeet7 and DJMmix
thanks for those answers and the advice, a friend told me this morning that i didnt need the objective c as it is a visual development subset used for creating mobile apps etc, so all i needed was the gcc c++ but he says its fine that it is there it will not be a problem and if i want to remove it just do so in the MinGw manager
so hopefully i will get a bit of time at the weekend to play about with it
Thanks!
Thanks!
- Jay
