New LA Bands 2 EQ
Re: New LA Bands 2 EQ
Postby wlangfor@uoguelph.ca » Fri May 17, 2019 7:27 pm
Here's My latest track BTW, it's indicitive of the colour as the LA Bands 2 EQ was the only EQ I used to mix it with.
My youtube channel: DSPplug
Postby wlangfor@uoguelph.ca » Sat May 18, 2019 2:15 pm
BTW, I had to look around for these peaking EQ filters by Michael Benjamin. I guess I had retrieved them from naiante.com.
These are by MJ and optimized by Michael Benjamin Voigt and Infuzion.
1156_PeakingEQ1.8MJasm.osm
Peaking EQ by MJ
(111.13 KiB) Downloaded 1110 times
Postby Halon » Sun May 19, 2019 7:02 am
wlangfor@uoguelph.ca wrote:
Halon wrote:Is this a clean eq or does it add color?
No colour, a smoothness though. I'm uploading the knob right now to the knobman gallery.
It's a bit heavy handed in the upper mids though. I might smooth that out in a small way.
I do like color and mojo though.
Halon
Postby wlangfor@uoguelph.ca » Sun May 19, 2019 12:42 pm
I used to as well, but now I like sustained transients. Only achieved of course by properly calibrated attack and release. You know I realized that only Ruby was able to get euler's constant to work with that to any kind of exacting degree.
That Ruby example's in My Esquire Limiter. I find it useful but I'll be making another version that doesn't sound so "firm" and analog. I'll make the same limiter with a more relenting and airy release.
I achieve that by adding a gain rider. I'll add an exponential governor by calculating averages for varied benchmarks like -6 and -13. That way it still peaks beyond but it's averaged. I'm not a fan of brickwall limiters. They are sometimes nice with lofi samples and drums maybe though.
Postby wlangfor@uoguelph.ca » Wed May 22, 2019 3:12 am
Here's a new track; it's eighties revival. Made with Bands 2 and the Esquire Limiter:
It's a big project though. months to master
EDIT: Halon, btw. This EQ of mine has all kinds of Colour:
http://dsprobotics.com/support/viewtopic.php?f=2&t=14696&p=54811#p54777
Postby wlangfor@uoguelph.ca » Thu May 30, 2019 5:50 pm
Just updated this EQ. It works faster and it uses less memory.
Postby Halon » Tue Jun 04, 2019 8:26 pm
wlangfor@uoguelph.ca wrote:Here's a new track; it's eighties revival. Made with Bands 2 and the Esquire Limiter:
Thanks Robert. Will check out that eq
Halon
Postby wlangfor@uoguelph.ca » Tue Jun 04, 2019 8:29 pm
Yup, I just have to figure out an algorithm for making it quieter. Maybe My new zipper modification will be good for that.
Postby trogluddite » Sun Jun 09, 2019 10:51 pm
[moderator comment:trog]
Some following posts have been split off into their own thread: Language Corrections
Postby wlangfor@uoguelph.ca » Tue Jun 18, 2019 6:22 pm
So, I realize that people on this board don't like commenting on music lol, but look at this closely. I made a screenie with music of atrack that has about 72 instances of the LA bands 2 EQ as well as one instance of the freq and the LA bands 1.
[click to watch Youtube video]
