Drum detector (stream to midi)
• Page 2 of 2 • 1, 2
Re: Drum detector (stream to midi)
Do you need a hand with something KG? I'm a lot better at design and conceptual aspects than technical implementations. Happy to throw ideas at you if you're looking for them. Or is it more you know what you want to do but don't care to do the work involved (that's more my problem
- Perfect Human Interface
KG_is_back wrote:Youlean wrote:Too bad, you seam like really skillful person...
What do you have in working form?
For example this string modeler. I have improved the algorithm drastically (now it calculates the stuff practically instantaneously), but it still has no GUI and I'm struggling with creating the DWG-synth that would use the measured models (the model file format is also improved).
Also I have made a "midi to multivoice-poly" module that instead of playing all valid voices just randomly picks one. That is very useful for creating drum samplers (where you need to partially randomize the samples but scale them by velocity) which I have not finished until today.
That Synth would be awesome... I really hole that you will finish something soon...
- Youlean
