Quilcom Wavemaker 2: Make waves and save as .txt
Re: Quilcom Wavemaker 2: Make waves and save as .txt
Postby Ricciardo » Thu Sep 24, 2015 3:55 pm
Indeed, the first triangle is square, i made the wrong copy...
its very simple to create the string wave prims
just output a green data string/array values into a string/float prim, and it automaticly draw the values on it...
Ricciardo
Postby Ricciardo » Thu Sep 24, 2015 4:33 pm
I had to fix some things, first the harmonic oscillator wasnt in the correct phase because i forgor to past an element...
then i fixed the prim source for the triangle... it sounds much better now
Add OSC 18x V0.2.fsm
(68.6 KiB) Downloaded 1201 times
Ricciardo
Postby Spogg » Thu Sep 24, 2015 5:33 pm
Ricciardo wrote:I had to fix some things, first the harmonic oscillator wasnt in the correct phase because i forgor to past an element...
This is coming on very nicely but I found the Saw 4f is still silent...
Postby Ricciardo » Fri Sep 25, 2015 5:27 pm
Yes, the float was all zero, its fixed in this v003
i also added a polarity invert button for the wave.
Add OSC 18x v003.fsm
(357.03 KiB) Downloaded 1170 times
Ricciardo
Postby Spogg » Mon Sep 28, 2015 1:12 pm
Ricciardo wrote:Yes, the float was all zero, its fixed in this v003
Getting really good now!
However (sorry!) there seems to be issues with the fourier addition graph. 2 points:
-f16 slider does nothing!
-From f9 and above the tone isn't pure. There is additional modulation visible and audible. This is most visible on the slider for f15 where you see and hear a big amplitude modulation when you just slide up that one. For f8 and below this isn't present at all and the tone sounds pure.
If you can resolve those points too this will be a great osc!
Postby Ricciardo » Tue Sep 29, 2015 5:34 pm
hmm yes... but that i think it was due to the fact i had to resize the panel...
but meanwhile i had this weekend another idea, wich i implemented a little bit different
i removed the harmonics and added a Sine line just like the others... i think its more balanced that way...
and you can randomize sines as well...
so now you can pretty much randomize each line of oscillator and get sounds more quicly, as well as being able to
bend/morph the sound from other different sources...
check the version 004.
Regards
addiction osc v004.fsm
(1.24 MiB) Downloaded 1189 times
Ricciardo
Postby Spogg » Wed Sep 30, 2015 10:24 am
This is a BIG change :o
I very much like the blending control too, and the wave displays around the knob is brilliant!
However (you're going to hate me soon!)...
I can see no front panel controls on the wave mixer modules. I can get to change the levels by seeing where the mouse cursor changes but that's working blind. In case this is a version issue I should say that I'm using Flowstone 3.08.1
I'm looking forward to the next version!
Postby Ricciardo » Sat Oct 03, 2015 11:16 am
Probably thats caused because of the font i used on the numbers...
you can check this new version wich uses a more standard font 'tahoma" and you will most certainly see it now...
addiction osc v005.fsm
(1.24 MiB) Downloaded 1172 times
Ricciardo
Postby Spogg » Sun Oct 04, 2015 5:01 pm
Yay!!
This is now really good and usable and I love it :D
Will it develop further? Maybe more partials would be a good step or am I being greedy? Possibly there is no need because you can mix in the harmonic-rich waves with the sines. If it was only sines then you'd need more...
Brillaint work and many thanks for sharing. Keep inventing!
