New PWM
Re: New PWM
Postby k brown » Mon May 11, 2020 9:43 pm
I noticed this produces pretty severe distortion/aliasing on higher notes - any way to smooth that out?
Does this maybe only work best in blue?
Re: New PWM
Postby BobF » Mon May 11, 2020 10:49 pm
BobsAllWaveformPWM_1a Antialiased and white.fsm
(994.08 KiB) Downloaded 1055 times
Hi Kevin,
Try this one!
Good luck, BobF.....
BobF
Re: New PWM
Postby k brown » Tue May 12, 2020 12:21 am
Thanks for that - however I would describe the results as a mild improvement at the expense of noticeably duller sound.
Re: New PWM
Postby BobF » Tue May 12, 2020 4:22 am
Hi again Kevin,
Unfortunately aliasing is common in many distortion and wave shaping devices. If you missed this post read it over for possibly a little more help.
Reducing aliasing of waveshaping using convolution.
Try the conv tanh.fsm and see if it helps any better than the anti-aliasing filter I added.
conv tanh.fsm
(867.53 KiB) Downloaded 1042 times
And last, you could also remove some of the 1 pole low pass filters from the 36db anti-aliasing filter, they are each 6db. This could add a LITTLE punch back in.
Good luck and please let me know how you make out.
Take care, BobF.....
BobF
Re: New PWM
Postby k brown » Tue May 12, 2020 5:43 am
A 'convoluted' answer! :) - I'll give it a try.
Re: New PWM
Postby adamszabo » Tue May 12, 2020 7:09 am
Bob, unfortunately the 36 dB filter is just a simple filter its not anti-aliasing at all. You cannot remove aliasing by simply filtering the signal with a low pass filter, its not how it works.
adamszabo
Re: New PWM
Postby martinvicanek » Tue May 12, 2020 9:36 am
A simple antialiasing technique consists in synthesizing the time integrated waveform and then numetically differentiate it. Example: a square wave is obtained by differentiating a triangle wave. The method is called DPW (differentiated polynomial waveform).
Re: New PWM
Postby k brown » Tue May 12, 2020 9:43 am
Easy for you to say! :shock: ;)
Re: New PWM
Postby BobF » Tue May 12, 2020 3:07 pm
My bad on the antialiasing filter, just found it in another schematic and well used it. Sorry!!!
Later then BobF.....
BobF
Re: New PWM
Postby BobF » Tue May 12, 2020 5:16 pm
Bobs3Freq_PWM.fsm
(836.92 KiB) Downloaded 1048 times
Hello all,
Had this laying around, so just thought I would add it for completeness.
Later then, BobF.....
@ Adam, it's fixed, very sorry!
BobF
