Synthmaker Greatest Hits
Re: Synthmaker Greatest Hits
Postby Spogg » Wed Feb 03, 2016 10:15 am
I've emailed support. I'll try a new topic and delete it if I'm still personally blocked...
EDIT: Yes I've been blocked from uploading any more.
I'm a bit p*ss*d off about this but maybe I'll get a reply soon.
Since I can still post I'll stick to Dropbox links for now.
Postby Spogg » Wed Feb 03, 2016 10:20 am
Pitchbend and mod wheels
Here are a nice pair of 3-D looking controller knobs; a self-centering pitch bend and a modulation wheel.
Note that they aren't MIDI aware out of the box.
Spogged: Nothing
Author: Loopeytunes
https://www.dropbox.com/s/cprk2icqkrfe1 ... s.fsm?dl=0
Postby Spogg » Wed Feb 03, 2016 10:23 am
Loopeytunes wrote:
Also the Drum Pads by me :P
Thanks Loopeytunes. I've edited the post to credit you as author.
Postby Spogg » Wed Feb 03, 2016 11:58 am
Vector knob designer
This knob designer has a separate wireless properties module inside the knob view.
It allows many parameters to be tweaked to get the knob of your dreams. When you have finally got your dream knob you need to save the whole module to your toolbox, not just the knob view inside the module; the properties module is always needed otherwise you will lose your knob.
And nobody wants to lose their lovely knob.
Spogged: Nothing
Author: Original by nix then developed by stw and possibly others not listed.
BTW admin have allowed me more uploads. Yay!
triangleknob v1.4 .fsm
(508.16 KiB) Downloaded 1468 times
Postby BobF » Fri Feb 05, 2016 1:30 pm
Hello Spogg,
Say did you ever get an answer to your blockage. Very odd they would block someone after so many uploads.
Take care, BobF.....
BobF
Postby Spogg » Fri Feb 05, 2016 1:50 pm
BobF wrote:Hello Spogg,
Yeah I contacted support and they gave me more allowance immediately. So I was impressed by the speed of this being corrected.
I think the idea is to put a limit in place to reduce the likelihood of denial of service attacks where someone could just continue to upload all the time via a script, but what do I know? Just my thought. I believe the attachement limit can be set globally too, not just per-user. I had a look at some PHPBB forums and this seems to be the case.
Postby Spogg » Sat Feb 06, 2016 10:47 am
Switch collection
I plundered the old site data looking for switches and this collection is the result. Here you'll find rockers, slides, toggles and more. There are horizontals, verticals, two and three position versions.
All good in my opinion, so go ahead and swell your toolbox!
Spogged: I pasted all the stuff I found into one FSM for convenience.
Authors: One collection is by Noisemaker pro (labelled as such in the FSM). Others unknown.
Switch collection.fsm
(1.23 MiB) Downloaded 1558 times
Postby Spogg » Sat Feb 06, 2016 2:08 pm
16 pad drum player
This is a 16 pad drum player with right-click for load and MIDI learn. It's clearly using the pad I uploaded recently and it's in a nice looking GUI.
This version of the pads responds with volume to the vertical position of the mouse when a pad is clicked. There's an area at the top right where I assume the author intended to put additional controls and effects possibly.
It comes pre-loaded with some nice samples so it's ready to play on opening.
Spogged: nothing
Author: Loopeytunes.
16PADs.zip
(1.12 MiB) Downloaded 1547 times
Postby Loopeytunes » Sat Feb 06, 2016 3:08 pm
Yep, those are the pads from my Drum Pad but I cannot remember making the 16 pads and that GUI. If I did make it then my old age is starting to kick in haha
Loopeytunes
Postby Spogg » Sun Feb 07, 2016 1:24 pm
GUI kit collection
I found several posts of "GUI Kits". These contain loads of GUI elements like knobs, sliders, LEDs and much more. The file names in the zip give an indication of what's inside in most cases. Well worth investigating for your toolbox's sake.
Spogged: Nothing changed. I selected the most recent posts for each variation. For clarity they are left separate in the zip since there are so many elements it could be confusing if put into just one FSM.
Author: Unknown
GUI Kits.zip
(1.33 MiB) Downloaded 1599 times
