La Voz Cantante: a 512 Channel Vocoder
Re: La Voz Cantante: a 512 Channel Vocoder
Postby Spogg » Sat Sep 14, 2019 8:55 am
Oh dear, the routing issue was my stupid fault after all. :oops:
The rpp you sent me worked fine and I realised I’d misunderstood the pdf. :oops:
For some crazy and insane reason I thought you were saying to insert the VOZ as an INPUT FX, which was the actual problem. The pdf image shows clearly that this is not the case.
Sorry for causing you extra work and anguish.
Postby Halon » Fri Oct 11, 2019 11:01 pm
Wonderful! Thank you Martin!
Halon
