Synthmaker Greatest Hits
Re: Synthmaker Greatest Hits
Cassette player
Now here's a novelty for you. Load a wav file and play it on this retro Philips cassette player. The animation is really cool! Plus, you must try the fast forward and reverse keys
Spogged: Loaded a 30 second test file (which is why this is 20 megs). Fiddled with the "tone" filter settings.
Note that the Record key isn't connected but I bet someone will make that work...
Also a click sound for the keys would add something...
Author: Unknown
https://www.dropbox.com/s/j8mmlqem3bvhn ... t.zip?dl=0
Author: Unknown
Giraffe knob
Here's another novelty for you. A knob which is a chewing giraffe. Cute or what?
Spogged: Fiddled with the properties for the knob and the demo counter.
Author: Unknown
Author: Unknown
giraffe nom nom knob.fsm- (552.8 KiB) Downloaded 1638 times
Constantly rising tone
I've always been fascinated by this sonic illusion:
https://en.wikipedia.org/wiki/Shepard_tone
The author has made a module which creates configurable Shepard tones. You can use the LFO or even play the effect on your MIDI keyboard. Fool your brain!
Spogged: Nothing
Author: Martin Vinacek
Spogged: Nothing
Shepard.fsm- (183.84 KiB) Downloaded 1642 times
Peak hold dB readout
A readout of the peak audio signal level in dB.
To restart the readout you left-click on the display. The evaluation is in ASM.
Spogged: Added a test environment.
Added a reset input.
Question: Is this calibrated or just for indication?
Author: Original unknown but this has been updated by Mo for ASM
EDIT 24.2.16: I found another one with a better Reset input. Not tested by me.
Peak-Hold-Readout-Mo.fsm- With a trigget input for reset
- (1.21 KiB) Downloaded 1583 times
Peak-Hold-Readout-ASM-Mo.fsm- (66.47 KiB) Downloaded 1646 times
Calibration: I get identical readouts when comparing with 2 different toolbox module I've had.
RJHollins wrote:Calibration: I get identical readouts when comparing with 2 different toolbox module I've had.
Thanks RJ. So I guess we can trust this one!
The Shepard oscillator is another eraly creation of mine. Utterly inefficient...
martinvicanek wrote:The Shepard oscillator is another eraly creation of mine. Utterly inefficient...
Thanks Martin. I've amended the post
Another daft knob!
More fun with a knob!
Spogged: Fiddled with the knob parameters.
Author: Unknown
Author: Unknown
Stan and Ollie on Wall Street.fsm- (395.33 KiB) Downloaded 1635 times
