Synthmaker bundle
Re: Synthmaker bundle
Postby martinvicanek » Sun Feb 12, 2017 7:09 pm
For what I could see, the SVF3 filters in Multipoly do not hop the coefficients. Haven't checked your other synths, but I am sure they don't hop(128) when modulating at audio rate. Else you'd have noticed.
Postby k brown » Sun Feb 12, 2017 7:34 pm
I think what I'm beginning to realize is that in a few recent cases, I've used a different version of the SVF that I got from somewhere that are not the original SM SVF. Someone wrote a different code but the module's still named "SVF 3" !
Thanks so much for your detective work !
Postby martinvicanek » Sun Feb 12, 2017 9:39 pm
Since the SVF3 is so popular I have fixed the tuning. It wasn't off by much, but now it is supposed to be accurate enough to use it as an oscillator. I have also fixed the coeff update code whihc was a bit awkward.
Happy filtering! :D
SVF3_Filter_optimized_tuning_fixed.fsm
(2.19 KiB) Downloaded 1027 times
Postby DrewDale » Sun Feb 12, 2017 10:19 pm
What is the upper left text supposed to say on the Spirit of spirit GUI shown here.
Untitled 1.jpg (6.69 KiB) Viewed 33871 times
DrewDale
Postby DrewDale » Sun Feb 12, 2017 10:24 pm
Just noticed more GUI / text problems on spirit of spirit, what is it supposed to say above the grey switch shown here ?
Untitled 1.jpg (7.28 KiB) Viewed 33870 times
DrewDale
Postby k brown » Sun Feb 12, 2017 10:25 pm
martinvicanek wrote:Since the SVF3 is so popular I have fixed the tuning. It wasn't off by much, but now it is supposed to be accurate enough to use it as an oscillator. I have also fixed the coeff update code whihc was a bit awkward.
Happy filtering! :D
Wow - thanks for doing that !
Postby k brown » Sun Feb 12, 2017 11:44 pm
DrewDale wrote:Just noticed more GUI / text problems on spirit of spirit, what is it supposed to say above the grey switch shown here ?
Thanks for pointing that out - short answer : GUI burn-in issue (as you probably suspected).
- long answer : I'd inadvertently left the label in the schematic after doing the burned-in
image containing all the unusual text. Since it was superimposed on the burned-in
image and my computer was rendering the schematic label correctly, the label was not
visible. Since your computer was rendering that text with a different font you got the
scrambled appearance - two fonts on top of each other.
Fixed now : https://www.dropbox.com/sh/eh0xrbsqnao1 ... eH0na?dl=0
Postby k brown » Sun Feb 12, 2017 11:49 pm
Happy filtering! :D
I don't suppose you still have Synthmaker lying around to save that with ? I don't have FS.
Or maybe just post the code and I can paste it in.
Thanks again.
Postby martinvicanek » Mon Feb 13, 2017 7:14 am
Here you go
SVF3 tuning fixed.osm
(2.13 KiB) Downloaded 994 times
Postby k brown » Mon Feb 13, 2017 9:44 am
You are a prince - thank you so much.
