Position Synced StepLFO
Re: Position Synced StepLFO
Postby Father » Mon Jun 01, 2015 1:54 pm
Perfect Human Interface wrote:If you are one the IL forums you should post there about it...
Actually i meant the next flowstone updates. I believe there is a function within vst sdk that returns the host ID. Am i right?
Father
Postby tulamide » Mon Jun 01, 2015 3:03 pm
Father wrote:Actually i meant the next flowstone updates. I believe there is a function within vst sdk that returns the host ID. Am i right?
Yes. See here: viewtopic.php?f=3&t=2732&p=14781#p14781
Postby StereoSpace » Tue Jun 02, 2015 6:07 pm
Thank you Nubeat7! I could not solve the problem of sync in my plug-in, and now it works!
GUI designer
StereoSpace
Postby lalalandsynth » Mon Oct 22, 2018 4:57 pm
"did you unwire the pseudo host inside the ppq sync module? there you need to connect the timesig from host and the host ppq primitive, i was using a pseudohost module for testing inside FS, forgot to unwire this"
What do I need to change for this to work , what can I connect instead of the Pseudo host , I am a bit confused by this ,will it not run without the pseudohost in FS ?
EDIT: I see, It runs in a daw when hooked up properly , just needs the pseudohost for running in FS.
lalalandsynth
Postby Nubeat7 » Thu Dec 06, 2018 9:55 am
You are right, the pseudo host just imidates the playpositionmarker of a daw, it also is purgeable, so it will be deleted when you compile your project. Then, when be used as vst, it will use the ppm from host.
Postby wlangfor@uoguelph.ca » Thu Dec 06, 2018 3:12 pm
This is really Cool Nubeat. I'll test it and tell You what I made with it.
My youtube channel: DSPplug
