Elektron Digitone
Re: Elektron Digitone
Postby k brown » Wed Mar 02, 2022 9:52 pm
Updated schem (now v1.003) in previous post - some bonehead errors in the Mod section knobs connections (only one in ea group was connected, and they weren't properly bipolar).
Postby Duckett » Thu Mar 03, 2022 5:09 pm
Hey, thanks for the update- but there were some mods I'd made to the .fsm and wanted to check if I'd missed your errors as well, but the zip only contains the .dll, no schematic ;)
Duckett
Postby k brown » Fri Mar 04, 2022 1:27 am
Oops, sorry - corrected now.
Postby DSPRU1 » Tue Apr 19, 2022 8:37 am
Nice. It's going to take me a while to look at all these files. Here is my contribution to the cross-fade idea. An inverted pan controlled a Ruby Tempo Synced LFO that can be used to do rhythmic cross fade between 2 sources. Or you can switch it to manual mode. You can change the x-fade pattern by using a different sequence in the script.
Ruby Crossfader 002.fsm
Made with FS 309.
(56.73 KiB) Downloaded 771 times
DSPRU1
Postby DSPRU1 » Tue Apr 19, 2022 9:28 am
I added an automatic random slide to the Harmonics in FlowTone but it still needs more testing and modifications. It's almost like an automatic random Wah Wah pedal without having to touch any sliders. I tried to keep slides pretty slow.
FlowTone v1.004.fsm
Use FS 309.
(1.3 MiB) Downloaded 800 times
DSPRU1
