Super Saw, another approach !
Hi Gang,
Yesterday I posted a really simple super Saw that demonstrated how 6 oscillators interact with the same waveform near the same frequency. It was not simple enough for my taste, and it had no manners.
Time for a rethink.
Yesterday afternoon I took a close look at Spogg's 7 Saw project. What a great piece of work, and some fabulous sounds.
Spogg also offers a terrific video with the project.
If it's about frequencies near one another interacting, could we use just one oscillator or function generator and some pitch shifters ?
Let's find out !
2 years ago I built a pitch shifter demonstrator, I resurrected it and put it to use here.
Using just one sawtooth function generator, I was able to generate 5 signals with some clever interaction possibilities.
It's Dead Simple, the way I like it, and the sound is really pleasing !
Once again, I am not trying to emulate the Roland Super Saw, this is a whole new approach.
Also, you will see a fine piece of code in the box that I did not write.
Sadly, whoever DID write it did not SIGN it, so I have no idea who to thank !
But thank you anyway, it's the heart of my pitch "+/-" shifter modules.
Enjoy !
ROXY
Time for a rethink.
Let's find out !
Enjoy !
ROXY
ROXY Saw machine development-2B.fsm- Super Saw from a whole new perspective !
- (235.3 KiB) Downloaded 1064 times
rocknrollkat - Posts: 213
Re: Super Saw, another approach !
Nice idea to create the ensemble in the mono stream!
Essentially I would say this behaves like a chorus system. It should have a lower CPU than doing it all on the poly side too. Nice sounds as well.
Spogg wrote:Nice idea to create the ensemble in the mono stream!
Hi Spogg !
Yes, it is similar to a chorus, all slight detuning can be considered a chorus effect, etc.
It's so easy to get bogged down in semantic technicalities, sometimes it's necessary though.
You're right about the CPU usage, I haven't figured out how to do it any other way.
I'm glad you enjoy the sounds, more to come !
Your 7 Saw is pretty amazing, the preset names alone are worth the price of admission !
I enjoy your videos as well.
Best regards,
ROXY
rocknrollkat wrote:Spogg wrote:Nice idea to create the ensemble in the mono stream!
Hi Spogg !
"....You're right about the CPU usage, I haven't figured out how to do it any other way...."
I converted to white, CPU usage still too high, performance is terrible.
The delay lines don't like white.
Keep in mind that I'm not clear on what I'm doing here !
Here's what I did.
Best regards,
ROXY
ROXY Saw machine development-2C.fsm- Converted to white, no dice.
- (234.77 KiB) Downloaded 1085 times
Yeah you have to be really careful with delays in poly (white).
Best to avoid because every fourth new note played will dynamically assign a new and additional section of RAM. This takes time and causes high CPU bursts and horrible clicks.
If you simply MUST use delays you need to keep the maximum delay size to the barest minimum, like if you need a 20mS delay don’t set a buffer size for 1 second!
I had this battle with my Quilcom PMS and couldn't do everything I would have liked.
[quote="Spogg"]Yeah you have to be really careful with delays in poly (white).
Spogg[/quote
Hi Spogg !
I built a tape delay a couple of years ago, the delay runs out to over 1,000 mSec., with no problems.
It's been used as recently as a month ago when I did a tape delay at 200 mSec. for Jerry Schneyer's recording studio in Austin Texas.
Here's the project, with the setup as delivered to Jerry. The music is C/W star from yesteryear, Don Woody, with his granddaughter doing a remake of his hit "Let's Make Like a Rock and Roll". Jerry asked me to put the "Sun Records" touch on it.
I sent him the finished .WAV file made from this setup. I tried to include a tape player here for you with the .mp3 version of the song on it, but it won't upload.
The Tape Delay settings are 'as delivered'. Add your own 'master' "tape machine" (.wav player) and play some music.
Try switching the echo machine in and out to hear the difference.
Also, set the delay percent to "0" for the classic 'slapback' sound.
I set the reverb percent to 99 to avoid positive feedback.
Enjoy !
ROXY
Spogg[/quote
Hi Spogg !
Enjoy !
ROXY
ROXY - for Jerry Schneyer - Tape Delay - 11-30-2017.fsm- So you like rockabilly ?
Here's my tape delay, just like the old days ! - (158.83 KiB) Downloaded 1065 times
Bill, I think you missed an important point!
Maybe I should have added that it’s never an issue in Blue. In the Blue stream the memory for any delay is assigned when the plugin loads so you can have any buffer (max delay) size you want. It’s the poly stream that assigns dynamically.
Hope that helps!
Spogg wrote:Yeah you have to be really careful with delays in poly (white).
Hope that helps!
Spogg wrote:Bill, I think you missed an important point!Spogg wrote:Yeah you have to be really careful with delays in poly (white).
Hope that helps!
Hi Spogg,
Yes, I guess I didn't really understand what you were saying.
I'm only now getting the 'hang' of the different operating modes, green, blue, white, dark gray.
Thanks for the clarity, it helps a lot !
ROXY
