Speech engine - Text to speech - Talking clock
Postby tektoog » Mon Dec 03, 2012 7:42 am
Hey all,
This is my first post on this forum.
This little project is a talking clock TekTooG
tektoog
Re: Speech engine - Text to speech - Talking clock
Postby Jay » Mon Dec 03, 2012 8:48 am
wow thank very much for this demo Tektoog i will have a play with it today! :D
what I would like to do is get the resulting speech into flowstone for further processing and create some kind of bizarre speech instrument! lol I don't know if that is possible but it sounds fun!
Best Regards
Jay
Postby trogluddite » Mon Dec 03, 2012 9:52 am
Welcome to FS, tektoog, nce to see you.
Cool example too! :D
Postby ccpurno » Mon Dec 03, 2012 4:32 pm
vey cool proof of concept!
could this be done directly through ruby?
to prevent the need to run as admin and open up possibilities for vocal effect generator plugins etc.
CC
ccpurno
Postby unkargherth » Tue Dec 04, 2012 2:10 pm
@ccpurno: .. i'm trying
Ok firts try..... DON'T WORKS
Scenario i'm trying to amll MS TTS via OLE Automation ( or so I think). Afeter some hour of digging the web i came up with the following. I'm stuck because i'm NOT a windows programer ( i came fom unix world), so i post here hoping some MS Guru is able to finish it, or, at least give me some directions
require "Win32API"
# CLSID_SpVoice as per http://grokbase.com/t/python/python-list/092cy5hgm7/tts-in-windows
CLSID_SpVoice="96749377-3391-11D2-9EE3-00C04F797396"
# CLSCTSX_ALL as per http://msdn.microsoft.com/en-us/library/windows/desktop/ms686615%28v=vs.85%29.aspx
CLSCTX_ALL=23 #(0x17)
#IID_ISpVoice as per (where the hell its that "DEFINED")
#http://www.masmforum.com/board/index.php?topic=17911.0
#IID_ISpVoice  GUID <06C44DF74h, 072B9h, 04992h, <0A1h, 0ECh, 0EFh, 099h, 06Eh, 004h, 022h, 0D4h>>
IID_ISpVoice="6C44DF74-72B9-4992-A1EC-EF996E0422D4"
def doit
   #api = Win32API.new('user32','MessageBox',['L', 'P', 'P', 'L'],'I')
   #api.call 0,"Hello Win!!","Alert",0
   begin
      # Initialize COM
      api=Win32API.new("ole32", "CoInitialize", ['P'] , 'I')
      api.call(0)
      # Create Voice Interface Object
      pVoice= '\0'*8
      # CoCreateInstance ( CLSID_SpVoice, NULL, CLSCTX_ALL, IID_ISpVoice, (void**)&Voice );
      api=Win32API.new("ole32", "CoCreateInstance", ["P","P","I","P","PP"],"P")
      hOLE=api.call(CLSID_SpVoice, nil, CLSCTX_ALL, IID_ISpVoice, pVoice )
      watch "OLE" ,hOLE
      watch "pvoice", pVoice
=begin
      # TODO
       # Speak!
       # Voice -> Speak ( L"Hello World!!!", SPF_DEFAULT, NULL );
       # Not sure about it
       api= Win32API.new("sapi","Speak",["P","P","P"],"V")
      @aLines.each { |x|
         api.call(x,0,nil)
      #TODO
       # Shutdown the voice
       # Voice -> Release(); Voice = NULL if pVoice != nil
=end
       # Shutdown COM
       # CoUninitialize ();
       api=Win32API.new("ole32", "CoUninitialize", ['P'] , 'I')
       api.call(0)
   rescue Exception => e
      watch e.message
      watch "Exception", e.backtrace.inspect
The problem is That the call to Win32API for CoCreateInstance is returning a void pVoice pointer and unknown error (2147746132 is an error code, isn't it?) and i don't know how to continue from here
Any help would be appreciated
Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend
unkargherth
Postby tektoog » Wed Dec 05, 2012 7:28 pm
Hey,
Thanks for your comments guys ;)
How come I don't have forum notifications in my email like with the SM forum?
Edit: I guess I had to subscribe to the topic :oops:
tektoog
Postby Tronic » Thu Dec 06, 2012 6:07 am
You could take a cue from here.
https://github.com/djberg96/win32-sapi
Tronic
Postby unkargherth » Fri Dec 07, 2012 10:35 am
@Tronic: Thanks for the info. I've been digging around there and there's a lot of useful info. Anyway, without beign able to use "gems" i will need a bunch of time to investigate inside the win32-api ( not WIn32API) structure and hierarchy before being able to use it inside FS3
unkargherth
Postby tester » Sun Oct 06, 2013 11:18 am
Something talks here.
Questions:
How to change speaking voice? (how to get list of voices in the system?)
How to change properties of speaking voice?
In other words - how to integrate fully operational TTS into FS app?
Users browsing this forum: No registered users and 80 guests
