Controller Xbox360
Controller Xbox360
I would like programming xbox controller with code like AHK (AutohotKey)
but i'm not used to code with Ruby. Can u help me to assign Button A to F1 function ?
If you have any documentation about programming controller, i will appreciate it !
Many thx !
Many thx !
xbox360.fsm- (25.21 KiB) Downloaded 1811 times
- Almeida
Re: Controller Xbox360
Here are two modules that send key status messages to the current active window. It uses win32Api, which is a little bit hard to read. Check the FS user guide (page 198-201)
key strokes (MyCo).fsm- (26.64 KiB) Downloaded 1918 times
MyCo - Posts: 718
0x70 is just hexadecimal, you can use the windows calculator to convert it into decimal, or just use an online converter like this:
http://www.rapidtables.com/convert/numb ... ecimal.htm
Or you can use FS "hex to dec" primitive
Edit: Looks like you found your answer already
MyCo - Posts: 718
yes i found it finally but can help other ! thx
- Almeida
i have some code in AHK which move window at some position X,Y on the screen when i push Right on my keyboard
Right::
WinGetActiveTitle, Title1
WinMove, %Title1%,, 938, 10
then do you think it' s possible to do the same with Flowstone?
Cause have already link Right of 360xbox to send "Right" but its not read by AHK when both are open ( AHK & Flowstone)
Right::
- Almeida
It can be done with 2 other WinApi functions (GetActiveWindow and SetWindowPos). I'll have a look at this tomorrow, or maybe someone else is faster than me
MyCo - Posts: 718
this is an example of code to define the size and position of the window.
require 'Win32API'
def event i
# winapi GetSystemMetrics
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms724385(v=vs.85).aspx
# get current windows size
screen_width = Win32API.new("User32.dll","GetSystemMetrics",["L"],"L").call(0)
screen_height = Win32API.new("User32.dll","GetSystemMetrics",["L"],"L").call(1)
# winapi FindWindow
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms633499(v=vs.85).aspx
findWindow = Win32API.new('user32', 'FindWindow', ['P','P'], 'L')
# define your windows name here
windows_name = 'FlowStone - [Schematic1*]'
hWnd = findWindow.call(0, windows_name)
# winapi SetWindowPos
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms633545(v=vs.85).aspx
setWindowPos = Win32API.new("user32.dll", "SetWindowPos", ['I','I','I','I','I','I','I'], 'I')
# Struct SetWindowPos
# set windows size when moved (this is one of many options)
cx = 1024
cy = 768
posX = (screen_width/2)-(cx/2)
posY = (screen_height/2)-(cy/2)
# see uFlag option
uFlags = 16384
#Call SetWindowPos
return_SetWindowPos = setWindowPos.call(hWnd, -2, posX, posY, cx, cy, uFlags)
watch 'hWnd', hWnd
watch 'returned value from SetWindowPos call (If the function succeeds, the return value is nonzero.)', return_SetWindowPos
digitalwhitebyte - Posts: 106
This code works fine when i use it in Flowstone but i would like to do this in the current window. I saw someone talk about enumwindows function (http://msdn.microsoft.com/en-us/library ... 85%29.aspx). I didn't find the way to implement it. Can u help me to do this?
- Almeida
in my code you have modify the red contents of this variable to match your app name windows
P.S.
EnumWindows work in conbination of EnumWindowsProc, the current Win32API not support callback.
P.S.
