String Copy/Paste
String Copy/Paste
Postby tiffy » Sat Nov 09, 2013 7:55 pm
The Schematic can Copy/Paste a String from its Input to an Output. The Copied Value is held in one Output until Pasted to the other Output.
Note that this is not the same as Ctrl + C/V since if you had just copied and pasted something with this schematic and you then hold down Ctrl + V afterwards, you will paste something totally different into the output of the schematic.
String Copy-Paste.fsm
(188.02 KiB) Downloaded 1218 times
tiffy
Re: String Copy/Paste
Postby RJHollins » Sat Nov 09, 2013 8:46 pm
Works nice .. thanks Tiffy !
8-)
Postby MarvinMeller » Sat Nov 09, 2013 9:01 pm
Thanks :D would like support for copied strings/numbers outside the prog using Ctrl + C but dont know if its possible using Ruby :(
MarvinMeller
