Bobs "Ring Synth"
Bobs "Ring Synth"
NOTE: Rar file contains the fsm and exe, this text in pdf, and a Midi tune, "Pop Corn" , played on the "Ring Synth".
Hello Gang,
Following Spogg’s lead making percussion instruments, I made this percussion synth. I call it “Ring Synth”, because of the way it works. Basically, it’s six filters set right on the verge of oscillating. When a sharp pulse is sent to them, they RING (a burst of sound at the resonant frequency).
Features:
1. Midi input with velocity.
2. Six ringing filters, three 24db "Chebyshev" filters and three dual "State Variable" filters in series, and one noise source.
3. A selection of wave shapers to add harmonics, rectifier (half & full), sigmod to square, 1/2freq (sub) ( 3 filters only), Sub plus 2xFreq, and Ring Modulator.
4. Three lfo’s, used mostly for special effect sounds. LFO 1 is for filters 1 and 5, LFO 2 is for filters 2 and 6, and LFO 3 is for filters 3 and 7.
5. ADSR envelope control, mostly used for attacks.
6. The ability to use the output of filter 3 to trigger filters 5, 6, and 7.
7. One Arpeggiator.
8. One Scope and One FFT analyzer
How to use it:
To start make sure all the LFO’s are at zero (depth knobs), waveshapers are on thru, sigmod is disabled (little white button (white NOT green)), Ring Modulator is not selected (little white button), 3 out to 5,6, and 7 is also NOT selected (also, little white button), and ADSR is set for no attack and a long decay, or just start playing with the presets. Make sure the filters resonance is set just below oscillation (at least .9xxx). Select an octave range, start around 4 for the Chebyshev filters and -3 for the State Variables, and set tuning pointer near straight up (Study the presets). Adjust the volume and play some notes. Again, PLEASE STUDY the presets for a while and you should soon be making your own cool percussive sounds.
Note: all filters settings(LP,HP,etc) work except "Band Reject".
Cautions, watch your volume when experimenting! Some settings can cause wild oscillations, howling, and so on.
Have fun and PLEASE post your comments and patches.
Later then, BobF.....
- BobF
Re: Bobs "Ring Synth"
Thanks Bob, I'll check it out and make some patches for it. Ring huh? Interesting maybe.
Interesting approach Bob and thanks for sharing.
It seems capable of a huge range of sounds and that’s always fun to explore.
Now I’m sure by now you expect me to find “issues”,
so here’s what I found:
When these points are addressed I would love to have another look and dig a bit deeper.
- I can’t turn the ARP off (other than by deleting all the notes).
There are several duplicate preset parameters, highlighted in the attached document.
It would be nice to have an INIT preset to set the synth up as per your info.
Duplicate preset parameters_.zip- (11.32 KiB) Downloaded 978 times
Thank you Bob.
Best Regards
Phil
Best Regards
Phil
Phil Thalasso - Posts: 150
Very interesting concept, Bob. Thanks for sharing
kortezzzz - Posts: 763
