Pad selectors(or "radio" selectors)
The current assignment I got from Trog is a bit hard, so i took another detour.
Here's some pad horizontal/vertical Pad selectors.
Has 3 main features, that prevent me from building a damn new selector every 5 min...
1.Choose amount of selections
2. Re-sizable
3. Has an output for alternate values, ready to go..
Have done small test with PM and is working great.
NEW VERSION A FEW POSTS DOWN....
2. Re-sizable
Re: Pad selectors
Thats really cool Billv
I will defo find use for this! Cheers!
Kind Regards
Kind Regards
- Jay
Re: Pad selectors
This is very cool.
There's a small error when you click on the borders between the selectors.
- Perfect Human Interface
Re: Pad selectors
Perfect Human Interface wrote:small error when you click on the borders
Yeh, your right. Thanks mate. I left the mdown on float when it should be int.
Bugfix:
In MouseLDown, change
(For horizontal Selector..)
@x=x # change this to
@x=x.to_i
(For vertical Selector..)
@y=y # change this to
@y=y.to_i
BTW...a better example of this sort of thing is available...
check out the selector in this fsm by trog....creates columns/rows at the same time...
http://www.dsprobotics.com/support/viewtopic.php?f=3&t=601#p1962
Re: Pad selectors
..is still there
Selectors are not recommended unless you know what your doing and can fix/rebuild.
Re: Pad selectors(or "radio" selectors)
I finally found the bug...was looking in wrong place for ages...
Here's the fixed versions...
Bug was here... > was changed to >= in both lines.
x=0
@points.times do |x|
@pos[x]=@y if @x >= @p[x] and @x < @p[x+1]
@val[x]=1 if @x >= @p[x] and @x < @p[x+1]
x += 1
oh ... this is real nice
Just had a quick peek ... real nice how you have it to setup number of choices ... AND, having vert/horiz versions.
Very useful ... toolbox material.
Thanks Billv !
Thanks Billv !
Great job, man. Radio buttons always find their way to my stuff. Thanks a lot.
kortezzzz - Posts: 763
i really like the concept of this selectors, thanks for sharing billv, but it could be done much easier and more lightweight,
i kept the concept and all features and cleaned up the properties so that everything can be set there, you also can set horizontal or vertical now in the properties, so its both in one
Pad Selectors_nubeat.fsm- (84.13 KiB) Downloaded 1209 times
Awesome nubeat7...
..a guru version. Everyone should be happier with it...
Lots of stuff i learn from this....Cheers.
Properties panel is great, but I'm always frustrated that i can't see results in
real time while "tweaking" parameters in properties panel...
So I added a preview of the "view" of the selector to the properties panel.
