Concatenate Arrays
Concatenate Arrays
Postby tulamide » Sun Aug 17, 2014 9:47 am
As the title says, this puts arrays in one big array. Modules for concatenation as well as reading separate sub-arrays back in are provided.
This demonstration version uses the preset parameter array for concatenation, but you can easily change this by replacing that prim with a normal array prim.
It can be useful if you want to save arrays for whatever reason.
multi_arrays_to_one_preset.fsm
(3.52 KiB) Downloaded 1116 times
Re: Concatenate Arrays
Postby RJHollins » Sun Aug 17, 2014 7:12 pm
Will definately check this out ! Always working arrays ;)
Thanks tulamide 8-)
Postby tulamide » Mon Aug 18, 2014 9:28 am
You're welcome :)
And thank you very much for the comment!
