Triggers Per Seconds Counter
Postby Youlean » Fri Sep 05, 2014 9:52 pm
It calculates how many triggers where received per second. It is sample accurate.
NOTE: ASIO/DS/Audio Out is needed to be present in the schematics.
Triggers Per Seconds Counter.fsm
(3.25 KiB) Downloaded 1143 times
Youlean
Re: Triggers Per Seconds Counter
Postby Perfect Human Interface » Sun Oct 05, 2014 5:07 pm
Hi Youlean. I made a much simpler version. :)
FYI, timing in green is not accurate in general, and the ticker primitives are based on very inaccurate Windows timers. Timing in Ruby is quite accurate though if not perfect (but once it's converted back into green it can't be considered 100% accurate).
Triggers Per Second v1.1_PHI.fsm
(28.23 KiB) Downloaded 1124 times
Postby Youlean » Wed Oct 08, 2014 2:26 pm
Perfect Human Interface wrote:Hi Youlean. I made a much simpler version. :)
Cool, indeed it is simpler...
BTW, do you have any site with all your work with Flowstone?
Youlean
Postby Perfect Human Interface » Sat Oct 11, 2014 12:04 am
All my projects are still WIP. I'm still a good bit newer to Flowstone than most of the other regulars here. I know some of them have some cool things they've made over the years. When I release some things I will post about it.
