Linear, quadratic and cubic interpolation
Postby tulamide » Fri Sep 05, 2014 10:23 pm
Since it is very abstract, I'm working on a sophisticated example. Meanwhile, if you're familiar with interpolation or able to understand it from the schematic, you might want to add these 3 modules to your toolbox.
If you take a closer look at the math, you will see that all modules only use addition, subtraction and multiplication, which means you could do a dsp code version from it and feed the t-value with a [0,1] mapped oscillator. You'd then have a vivid, dynamic base with four poles (in case of cubic interpolation) for whatever you want to modulate with it. Just a thought...
interpolation modules.fsm
(947 Bytes) Downloaded 1119 times
Re: Linear, quadratic and cubic interpolation
Postby tester » Fri Sep 05, 2014 10:26 pm
It would be good to add some streamy interpolation stuff to Exo's works too.
