Midi GUI Keyboard
Midi GUI Keyboard
DJBrynte asked for a keyboard module a few days ago and I made a quick keys module for him.
Here it is:
Update Log 27-10-14
Added:
- Set keys corner radius.
- Gradients on keys.
- Turn on or off the gradient.
- Transparency on the "Pressed" colour.
- Black key highlight gradient.
- Turn on or off the black key highlight.
Bugs Fixed:
- N/A
Update Log 26-10-14
Added:
- Redraw limiter (added by Exo)
Bugs Fixed:
- Double Trigger Note event when mouse clicking.
I will update this (when I get the chance) and add more user customization in it.
Here it is:
Update Log 27-10-14
Added:
Bugs Fixed:
- N/A
Update Log 26-10-14
Added:
Bugs Fixed:
Loopeytunes - Posts: 57
Re: Loopey Keys
still not working with selectors? :/
- djbrynte
Re: Loopey Keys
hi loopey tunes,
your keyboard doubletriggers note events,
you should choose between mLDown/Up or the drag on/off bool to trigger note on/off events instead of using both.
Re: Loopey Keys
Thanks, I'll take a look at it later today and fix it.
Re: Loopey Keys
Hi Loopey,
I fixed your keyboard so that it works with the old selector. It will need some more testing though because I am using the Thread primitive which is R&D, and I currently don't have a midi keyboard to test if it works with 'real' Midi.
Loopeytunes Keys v1.1.fsm- (8.95 KiB) Downloaded 1223 times
- Exo
Re: Loopey Keys
EDITED:
Ok my mistake, I turned the wrong MIDI device on lol it does work with "Real" MIDI.
Thanks
Thanks
Re: Midi GUI Keyboard
Try this one...
Loopeytunes Keys v1.0fix2.fsm- (9.1 KiB) Downloaded 1266 times
- Exo
Re: Loopey Keys
Loopeytunes wrote:EDITED:
Thanks
Lol the new one I just posted is probably better anyway (if it works fine) because it doesn't rely on the Thread primitive.
- Exo
Yep that works
I've sorted the double trigger note events problem that Nubeat7 mentioned, thanks
Used your fix Exo and updated the file in the first post. Thanks
Loopeytunes wrote:Yep that works
Great, thanks for sharing the keyboard
- Exo
