Trouble with poly stream. Could someone help?
Hi.
Im having trouble connecting the poly stream to the combiner in my synth project. Ive tried many things, even copying every module into a new schematic but nothing.
Could someone have a look?
Thank you.
Thank you.
- Halon
Re: Trouble with poly stream. Could someone help?
Hello Halon,
the problem lays with the displays.
I once did a filterbank in which I had to replicate the generators per display.
Have a good week-end and thank you for all your good work.
Best regards
Phil
Best regards
Phil
Poly stream problem_Phil.fsm- (1.75 MiB) Downloaded 938 times
Phil Thalasso - Posts: 150
Thank you so much Phil! Have a good weekend youself
- Halon
