Toggle and Flip-Flop module
Simple but useful, why are not listed as primitives ?
Toggle: alternates the logic output after each trigger.
Flip-Flop: a logic memory, with set and reset
- arend
Re: Toggle and Flip-Flop module
You can find something similar in the switch. Also the last "Not" in the toggle seems not to be needed.
Cheers.
Cheers.
- Morph
The last '"NOT" is just for initializes the output module w/ "0'" logic.
brgds
brgds
- arend
Here's an alternative Flip-Flop that is simpler and safer.
FLIPFLOP-2.fsm- (535 Bytes) Downloaded 2106 times
- DSP
DSP,
Understood, tks !
brgds
Understood, tks !
brgds
- arend
DSP wrote:Here's an alternative Flip-Flop that is simpler and safer.
Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
- fixstuff555
fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
Indeed, I am also a beta tester!
- DSP
DSP wrote:fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
Sweet... Can't wait to see it!
- fixstuff555
