Problem with mix saturation
Postby StereoSpace » Thu Oct 10, 2019 12:47 pm
Hi guys!
I want to create something like separation-frequency saturation (example. Saturation in nectar 3 by iZotope)
But, there is a problem with mixing the processed signal in to the original. Any modules cause unnecessary sound distortion, especially at 50%
what am I doing wrong? :(
By the way, this applies only to saturation and distortion schemes.
When working with compressors and delay, there is no such problem.
Thanks for the help!
Testbed 12AX7 mod.osm
(2.81 MiB) Downloaded 927 times
GUI designer
StereoSpace
Re: Problem with mix saturation
Postby martinvicanek » Sat Oct 12, 2019 4:40 am
Maybe a phase thing again? About band splitting and recombination you might want to check out my tut at FS Guru.
BTW, clipping results in a rather harsh form of distortion. You might want to consider some smoother transfer function like tanh(x) or x/sqrt(1 + x*x).
Postby StereoSpace » Sat Oct 12, 2019 5:39 pm
Thanks Martin! I'm going to your lesson right now))
GUI designer
StereoSpace
