FX Order - Extended
FX Order - Extended
FX Order is a tool that makes it possible to change the order of effect modules on the fly. You can find the original version by Nubeat7 here
Here is an extended version with 12 FX. Its very similar to the original work, but works with green selector instead of blue code. Works for me, so here i am sharing it with you.
Next step could be combining serial with parallel routing. But for now this is it.
Please report if you find anything wrong with it, I'll just ask Nubeat7 to fix it!
(I forgot to change a number and reconnect some wireless inputs, fixed now)
FX-Order Extended.fsm- (7.97 KiB) Downloaded 1268 times
- Father
Re: FX Order - Extended
You may make this type of FX order completely scalable using Buses. Bus works in very much the same way like selector.
KG_is_back wrote:You may make this type of FX order completely scalable using Buses. Bus works in very much the same way like selector.
I suppose that would be more efficient and organized too. Right now im thinking about having two lines for parallel processing. That needs some work on the chainer gfx module.
- Father
Doesn't this take much more CPU when switching busses?
- Perfect Human Interface
In what may be the reason, when you insert a preset manager into the scheme, then all the cells get off one and nothing can be done about it?
GUI designer
StereoSpace - Posts: 78
StereoSpace wrote:In what may be the reason, when you insert a preset manager into the scheme, then all the cells get off one and nothing can be done about it?
I cant test it right now, but I guess the preset manager clears out the default array, you should be able to copy the array before inserting the preset manager, and paste it later.
- Father
Father wrote:I cant test it right now, but I guess the preset manager clears out the default array, you should be able to copy the array before inserting the preset manager, and paste it later.
Big Thanks!!! Tomorrow I will try.
GUI designer
