Bryntes Knobman Pack Vol.1
• Page 1 of 3 • 1, 2, 3
Here are some knobs i made. and i wana share them with you. Feel free to use them in any project u like or change if u like to. (I mean edit the knobs if u like) NO neeed for credits or anything. I will make a pack 2 aswell. mybe a 3rd to.
I dont use those knobs so mybe you will have better use for them.
Bryntes Knobmanpack Vol.1.rar- (141.52 KiB) Downloaded 1588 times
- Bryntes Knobman Pack Vol.1.jpeg (80.25 KiB) Viewed 26131 times
- djbrynte
Re: Bryntes Knobman Pack Vol.1
Also if you have any specific knobs u like me to make. I can try to do them. i cant tell you i will make it. But i can do a try. For next pack.
- djbrynte
Looks good so far
will give some feedback when i load them properly, but great job on the visuals
- glitchcpt
Hey guys...
I dont know "*.knob" format?! Whats this?
How can I use this in a FS project?
Greetings
Frank
Greetings
Frank
- Sealab3000
search for knobman
@djbrynte: looking forward part 2 and 3?
Thanks 4 the knobman sources!
Keep on doing!
Walter
Keep on doing!
Walter
walter no problem i have like 500 diffrent knobs
some i modified and from scratch to.
- djbrynte
Sealab3000 wrote:I dont know "*.knob" format?! Whats this?
It's knobman's file format. Knobman is a design tool for generating bitmap-based knobs.
http://www.g200kg.com/en/software/knobman.html
Good stuff. Thanks. Just a little off topic note: too bad that the FS stock Ruby knobs can not adopt traditional buttons and are too hard to modify. Could be great if someone that understand ruby well was modifying them to load PNG
knobs and buttons easily. There is "Trog knob" around, but this knob is kinda overkill and needs an decent optimizing as well. Some more simple and usable Ruby knobs and switches would be welcome.
kortezzzz - Posts: 763
kortezzzz wrote:Could be great if someone that understand ruby well was modifying them to load PNG
Could you elaborate on that? What exactly do you expect from such a module. What should it feature to "load PNG
knobs and buttons easily"?
I know Trog's knob and of course the stock knob. But I never worked with knobman as a source of the generated bitmap. It seems knobman just generates a vertical strip (maybe horizontal also), so that should be compatible, or not?
I would like to see a set of feature definitions, to let me see if I can help here.
Knobman export following images.
BMP 24 and 32 bit
PNG
TGA
JPEG
GIF
ALL
BMP 24 and 32 bit
PNG
TGA
JPEG
GIF
ALL
- djbrynte
