Ruby/DSP Selectable Curve Crossfader
Hi Guys,
So I'm working on trying to construct a realistic sounding crossfader schematic,
And I can't seem to wrap my head around the ruby behind it, I have worked out most of the maths functions, but the if statements aren't firing correctly, I don't even know if that is the right method to use here haha
anyway, here it is so far
:edit:
I think I got the if statements firing off correctly, just need to figure out the last 2 equations
:edit:
Ruby CrossFader Advanced 0.2.fsm- (1.86 KiB) Downloaded 1285 times
- glitchcpt
Re: Ruby/DSP Selectable Curve Crossfader
Just had a little time 4 this...
here a simple solution for the last Type:
[using ur indentation]
but none 4 the 'Slow Fade'
Keep on doing!
Walter
##Fast Cut BUG? # after sun mod O.K.
if @index==5
if @x <=0.1
then
self.output 2, @x*10.5
else
self.output 2, 1 # sun mod
if @x >=0.9
then
self.output 3, (1-@x)*10.5
else
self.output 3, 1 # sun mod
Keep on doing!
Walter
I would use a min and max functions instead of the last if statements
- adamszabo
Good idea adam...
like this:
like this:
a = @fader >= 0.9 ? (1-@fader)*10.5:1
output 3, a
watch 'a',a
b = @fader <= 0.1 ? @fader*10.5:1
output 2, b
watch 'b',b
