Why I felt in love with Ruby
Postby tulamide » Tue Feb 03, 2015 1:08 am
I started programming back in the days when oop was just a wish. Since then, I worked with a lot of oop-oriented languages, but Ruby is the first that really fascinates me for its ease of use. Let's have a look at this (its not the full code, just an excerpt):
@example.each_line.with_index do |s, i|
      @value[i * 4 + 2] = s.chomp.split(" ").each {|s| s.capitalize!}.join " "
This is so close to the way human beings think, that I currently can't imagine any other language doing it better. Besides, these 3 lines of code represent what would have been dozens of code lines 20 years ago. But what is happening here?
A string input is said to be looped for each line of text, additionly giving an index. An array is told to store each line seperately. But that line of text is heavily altered. First, it gets rid of any control signs (like CR, LF, etc.) using chomp. Then that result line is split into single words using split with space as seperator. Those single words are now looped and each of them changed to start with a capital letter. And lastly all of them are joined together again, again using space as seperator. See? I can't even describe it as short as its written in Ruby while still instantly recognizable.
Awesome!
Re: Why I felt in love with Ruby
Postby MyCo » Tue Feb 03, 2015 1:42 am
PHP:
$foo = ucwords(trim($foo));
trim = remove whitespace
ucwords = uppercase words
PHP is quite old but still beats the crap out of the newcomers :mrgreen:
MyCo
Postby tulamide » Tue Feb 03, 2015 2:02 am
MyCo wrote:PHP:
To keep it fair, you just took a small part of the above ;)
Your example in Ruby:
@foo.split.map(&:capitalize).join
doesn't even need an assignment :D But yes, that PHP code is pretty cool.
Postby MyCo » Tue Feb 03, 2015 2:51 am
Ever tried ruby's string mangling stuff on German Umlauts? You'd be surprised :mrgreen:
MyCo
Postby tulamide » Tue Feb 03, 2015 9:44 pm
MyCo wrote:Ever tried ruby's string mangling stuff on German Umlauts? You'd be surprised :mrgreen:
I knew before that all the good stuff is limited to ASCII-7, and Flowstone doesn't allow us to use encodings :(
Have you ever tried to enter a german umlaut in the ruby editor? :mrgreen:
Postby cathleenwitmer » Fri Feb 20, 2015 6:44 am
So i have a question, its says i the manual that ruby can access functions from 3rd party dll's so do you think text to speech and speech synthesis could be brought in to flow stone apps/plugs? it something Ive been interested in for a while! soz to digress!
imran
cathleenwitmer
