Customizable Selector
Postby Youlean » Sun Mar 15, 2015 8:59 pm
This is customizable selector that I made.
It should work OK.
It can't go above 1000 lines for some reason...
V1.1
Optimized for speed.. With stream loading selected, it loads 100000 lines on string in 2s on my machine... :D
It accepts unlimited size (if your PC can handle it)...
Hold CTRL for fine tuning.
Speeded up loading.
V1.11
Bug Fixes
V1.2
Improved sliders behavior
Removed "Stream" loading, now it loads it with green with same speed
Fixed selection dissapeer bug
Youlean Customizable Selector V1.2.fsm
(151.73 KiB) Downloaded 1299 times
Youlean Customizable Selector V1.11.fsm
(150.2 KiB) Downloaded 1220 times
Youlean
Re: Customizable Selector
Postby RJHollins » Sun Mar 15, 2015 10:21 pm
wow ... there is some intense work that went inside that selector module. :shock:
First testing seems to be working well ... will experiment more.
Thanks!
8-)
Postby Perfect Human Interface » Mon Mar 16, 2015 12:45 am
Whoaa, maybe use some more module structure in your schematics. :P
I like this kind of concept for a selector though. Nice work.
Postby Youlean » Mon Mar 16, 2015 2:37 am
Thanks guys...
@PHI
Did you made this "Advanced Label" ?
Is there a possibility to edit the code to accept area so I can use it instead of default "Text Draw" primitive?
Yep, I am Ruby noob... :?
Advanced Label.fsm
(1.12 KiB) Downloaded 1235 times
Youlean
Postby TheOm » Mon Mar 16, 2015 4:33 am
Youlean wrote:Did you made this "Advanced Label" ?
I made it. Here, I changed it for you:
text draw.fsm
(1.08 KiB) Downloaded 1272 times
TheOm
Postby Perfect Human Interface » Mon Mar 16, 2015 7:08 am
Hey Youlean
You need to trigger a redraw when the input values have changed. Also if you added an input to set the current selection that would be very useful. I'd do these things myself but I can't make much sense of your schematic haha.
Also there's a minor visual bug where the hover highlight doesn't disappear when you drag the mouse off the top of it.
Postby Youlean » Tue Mar 17, 2015 5:55 pm
@TheOm
Thanks Om, this if very useful... BTW is there any way you can hack Ruby so we can use this rendering method for anything, like Smooth primitive?
@PHI
I have fixed this bug, and added input selection...
Youlean
