Thru Zero Flanger
Thru Zero Flanger
Postby BobF » Fri Jun 05, 2015 9:03 pm
BobsThruZeroFlange.fsm
(132.38 KiB) Downloaded 1078 times
Hello Gang,
Ok, I was mostly just playing around with this for myself, but I have some problems and could use some kind help please.
The problem at preset it is, it is kind of noisy, lots of clicks, crackles, and etc. So any thoughts on cleaning it up would be great. Also any other changes you would like to make, please feel free to do so.
Thanks all! Later then, BobF.....
BobF
Re: Thru Zero Flanger
Postby Perfect Human Interface » Sat Jun 06, 2015 12:40 am
Hi BobF
I simply replaced the delay with an interpolated delay here, which should solve your scratchiness issue.
BobsThruZeroFlange_interpolated.fsm
(134.25 KiB) Downloaded 1086 times
Sounds good with a little tweaking.
Postby BobF » Sat Jun 06, 2015 2:24 pm
Hi Perfect Human Interface,
Thank you so much, sound very clean now.
Until next time, BobF.....
BobF
