Quilcom Divider: Create sub-octave sounds and more
1 post
Hi all
The Quilcom Divider is an effect which takes audio input and generates sub-octave sounds that can be mixed. There is a tracking filter provided that can be set to give similar sounds over a range of input frequencies. This filter can track input volume and/or pitch.
The input LPF can be adjusted, using the scope to see the result, to give a smoother waveform for the zero-crossing needed to feed the divider chain. The divider mixer output scope can be used to see the resulting waveforms and to visualise any clipping.
I've made a few demo presets to get started with. I think the voice synth preset is fun to fool around with!
As with anything I upload please feel free to use and abuse and, as always, any type of feedback is very welcome.
Quilcom Divider 1.01.fsm- Sub-octaves and more...
- (161.16 KiB) Downloaded 1482 times
1 post
