(RUBY) The mysterious parents of Jack...
If you've played around with Ruby a bit, you probably stumbled across two undocumented Ruby instance methods: caption and parent.
While I already explained what caption does, it wasn't until now that I found out what parent is good for. Instead of explaining it, I'll show it to you in this little schematic.
I'm already trying to find any use for this...
parent.fsm- (1.27 KiB) Downloaded 1154 times
Re: (RUBY) The mysterious parents of Jack...
Can you use them to change names of parent an child?
Freaky stuff.
KG_is_back wrote:Can you use them to change names of parent an child?
I wish. But I couldn't find a way
MyCo - Posts: 718
Indeed, you were. And not just seconds, but years!
