Path Splitter
Path Splitter
Postby tulamide » Fri Jul 31, 2015 11:55 am
Two convenience modules:
1) path splitter
splits a file path into folder path and file name. Propery allows to have a trailing '\' either on or off.
2) filename splitter
splits a file name into name and extension. Property allows to have a leading '.' either on or off.
Any feedback helps encouraging. Thank you.
path_splitter.fsm
(923 Bytes) Downloaded 1192 times
Re: Path Splitter
Postby TheOm » Fri Jul 31, 2015 1:06 pm
Why reimplement functionality that's already in the ruby standard library?
path_splitter_rb.fsm
(1.02 KiB) Downloaded 1223 times
TheOm
Re: Path Splitter
Postby tulamide » Fri Jul 31, 2015 3:38 pm
TheOm wrote:Why reimplement functionality that's already in the ruby standard library?
tulamide wrote:Propery allows to have a trailing '\' either on or off.
Therefore.
