Freq cross over with gain control
Postby primeposition » Thu Sep 10, 2015 5:02 pm
cross over with gain output..fsm
(8.02 KiB) Downloaded 1322 times
Hi all,
Looked through some of the forum and found a couple of other users examples so I combined them,
wondered if it could be improved upon.
any ideas give me a shout.
I have found that the right hand box, freezes when I change bits in my schematic. and it looks weird when you move them about.
cheers
primeposition
Re: Freq cross over with gain control
Postby tulamide » Thu Sep 10, 2015 6:56 pm
I'll probably sound like a grumpy grandpa, or a not-so-welcomed picky teacher, but the very first thing you should learn besides creating something is how to connect prims/modules. Avoid crossing lines as much as possible and keep the lines lengths' short. Make use of wireless connectors for feedbacks. Minimize front panels that you only need in the top view.
I'm not telling that because of some style guide or something. No, it is just to let others and yourself have an easier time reading the schematic. Here's what it looked like after a couple of minutes of work:
schematic revised
Postby BobF » Thu Sep 10, 2015 7:02 pm
Hello tulamide,
Say, how did you get those right angle turns in your schematic? I would really love to learn that trick.
Many thanks, BobF.....
BobF
Postby adamszabo » Thu Sep 10, 2015 7:13 pm
Its in Flowstone options in Advanced called Link Curvature
adamszabo
Postby tulamide » Thu Sep 10, 2015 7:38 pm
It's even easier. Without touching your curvature setting, you can right-click a link line and de-select "curved" from the popup-menu. I just don't know, with what version this option was introduced. Probably 3.0.6
Postby BobF » Fri Sep 11, 2015 12:39 am
Much appreciated guys. Never even knew it was there.
I have an even better idea I will post soon. It would have to be Incorporated into 3.09 though.
Later then, BobF.....
BobF
Postby primeposition » Fri Sep 25, 2015 3:15 pm
Thank you for the feedback. Has anyone got any improvements they would like to share?
any explaintions to why the blocks might end up freezeing ?
Kind Regards
primeposition
Postby primeposition » Thu Oct 01, 2015 4:25 pm
Does anyone know how I would go about making the boxes into lines and just having points instead of big resizable boxes?
primeposition
